Usually start getting the bank 1 or 2 codes indicating a problem that the ECU cannot track to a specific injector. Limp mode, rough idle, power loss, etc are the result then the code pops.
The injectors solenoids are monitored for draw and resistance. When those go out of range too long it throws a code and goes to limp mode. If it shorts bad enough the ECU will shut down the whole bank and not reset until the problem is found. Needless to say that usually means dead in the water.
