Headed home from the station yesterday morning and noticed the 99 was sluggish. Fuel pressure is good at 12 psi (stock LP). Got home, hooked up to the boat and headed out, and it was still sluggish. Turned around, traded the 99 for the MegaCab and went & did my fishing...
TODAY: Started the truck, and the truck runs fine at idle, and easily goes from idle all the way up past 3000 RPMs. Back out, everything normal including fuel pressure, headed down the road, and the truck just doesn't want to go. Only builds about 6-8 psi boost, unless I put the accellerator to the floor where it only builds up to about 10 psi, but the RPMs won't climb past about 2000. Unplugged the Edge EZ and test drove, and no change. Checked and can't find a boost leak anywhere either. Did an APPS reset, and little or no change.
The only thing I CAN'T confirm is that the wastegate is stuck OPEN. Im unable to move the rod manually in either direction (and according to the guy at River City Turbo in Little Rock, I shouldn't be able to).
I also noticed that the truck wants to shift very quickly through second gear. The EGT's dont go past about 700 either. Checked and no codes were presented or stored either.
I'm at a loss here. I've fiddled with it all day and still can't determine the problem. Would REALLY appreciate some new ideas!
Craig
Craig
