VHCAMADAMS
Not really sure what your question is. Below is the information from the link in my previous post. Hope this answers your question.
Don
Mobil Delvac 1®
Product Description
Mobil Delvac 1 Synthetic high performance diesel engine oil contains high-quality synthetic base stocks and a unique additive system. Itprovides outstanding high-temperature detergency and
all-temperature dispersancy, with optimized resistance to thermal degradation and oxidation, wear, and corrosion.
Mobil Delvac 1 carries an SAE 5W-40 viscosity rating. It has all the advantages of an SAE 40 weight oil without the higher oil consumption inherent in multigrade oils that use very light-mineral oil base stocks. Because synthetics have higher boiling points than conventional oils, Mobil Delvac 1 does not evaporate as readily in the high-temperature piston ring area of
turbo-charged diesel engines.
Mobil Delvac 1 has the same viscosity as most SAE 40 oils at the high end of the temperature viscosity scale. However, because of its higher viscosity index and unique molecular structure, it provides a better protective film at higher temperatures than conventional oils. Mobil Delvac 1 remains fluid at sub-zero temperatures as low as -54°C (-65°F) and provides rapid cold-engine
start-ups and warm-ups.
Mobil Delvac 1 can provide satisfactory lubrication at temperatures up to 100 degrees above the upper limit for conventional mineral oils. It is fully compatible with conventional heavy duty diesel and gasoline fleet engines. It also provides unsurpassed protection against soot related
viscosity increases in low emission diesel engines.
Mobil Delvac 1 has long drain capability and can be extended in service far beyond the builder recommended drain interval in both diesel and gasoline engines. Consult your Mobil representative for specific recommendations.
Mobil Delvac 1 will provide outstanding wear protection and deposit control in the most
demanding diesel engines of Cummins, Caterpillar, Mack, Navistar, Detroit Diesel, and others. It is balanced to provide optimum engine life until overhaul,in both high-loaded, thermally stressed
diesel engines and units operating at lower speeds in pickup-and-delivery service.
Mobil Delvac 1 exceeds the requirements of:
API CH-4, CG-4, CF-4, CF, SJ, SH
Mack EO-M Plus, EO-M, EO-L Plus
Cummins CES 20076, CES 20071
Detroit Diesel 7SE270
Volvo VDS
MTU/DDC Category 2
Caterpillar deposit performance
2. 0% distillation at 700°F
Applications
Mobil Delvac 1 is recommended for diesel- and gasoline-powered fleet vehicles, such as
over-the-road, off-the-road, truck rental, pickup-and- delivery, utility, and school bus fleets. Mobil Delvac 1 is capable of providing fuel economy benefits of up to 3% and more in heavy duty diesel engines, with as much as a 40% reduction in oil make-up in over-the-road service.
When Mobil Delvac 1 is used in an engine for the first time, no system preparation is necessaryother than proper draining and installation of a new filter. In an emergency, conventional oil can
be used as make-up for Mobil Delvac 1, but such mixing may lower the performance of Mobil Delvac 1. Do not dilute crankcase oil with gasoline or kerosene in cold weather. The diluent will not improve cold cranking and may have an adverse effect on the performance of Mobil Delvac 1.
In addition, Mobil Delvac 1 is recommended for extended drain performance in truck
trailer-mounted refrigeration units.
Typical Characteristics
Typical characteristics are shown in the data table.
Mobil Delvac 1
Product Number 44111-3
SAE Grade 5W-40
Gravity, API 32. 3
Pour Point, °C (°F) -54 (-65)
Flash Point, ASTM D 92, °C (°F) 230 (446)
Viscosity
cSt at 40°C 95
cSt at 100°C 15. 0
SUS at 100°F 481
SUS at 210°F 79
Cranking Viscosity, cP at -25°C 3,200
Pumping Viscosity, cP at -35°C 20,500
Borderline Pumping Temperatue -44C
Sulfated Ash, wt % 1. 3
TBN, ASTM D 2896 11
Color, ASTM 15005 5
Advantages
New super high performance in both diesel and gasoline engines
Performance surpasses all conventional oils
Enhanced TBN wear/cleanliness protection
Diesel quality reserve for longer engine life
Extended engine life until overhaul in 1998-certified and pre-1998 diesel engines
Superior soot control in 1998- certified diesel engines
Enhanced protection against bore polishing and engine scuffing
Unique oil consumption control
Extended high-temperature and stop-and-go gasoline performance
Wide-temperature-range protection
Long drain capability
Documented fuel economy
Health & Safety
Based on available toxicological information, this product poses no significant health risk when handled and used properly. Information on use and handling, as well as heath and safety information, can be found in the Material Safety Data Sheet which can be obtained from your either your local distributor, the Internet
http://www.mobil.com; or by calling 1-800-662-4525 and selecting prompt 2.
For additional technical information or to identify the nearest U. S. Mobil supply source, call 1-800-662-4525.
Mobil Oil Corporation
TECHNICAL PUBLICATIONS
3225 Gallows Road, Fairfax, Virginia 22037-0001
"The Shadow" 1999 Dodge Ram SLT 2500 QC 5spd 3. 55lsd, Short Bed, Sport, Black / Tan Interior, Trailer tow package, Camper package, Infinity sound.
Remember Friends don't let friends drive Powerchokes.
Lapeer, Michigan
