I if you averaged 60mph you was getting on it. It is hard to average a 60mph.
2 things to think about when calculating mileage... catalytic converters were put on diesels starting in 04, second, ultra low diesel fuel. Engines (other than 07. 5 & up made for higher sulfur content. You lose about 1% on fuel due to lower BTU value (less then 8 PPM sulfur). And last if you get a new diesel you also have a exhaust filter to put up with (EPA stuff). You have to clean them every 100K or so and can only run UL fuel. With my last 2 diesels pulling 7500 LBs I average 13 to 15. 17 unloaded. dj
ULSD has about a 1-2% lower BTU content than LSD which provides an expected 1-2% MPG loss.
$5. 41/gal. in Kona as of 7-3-08. water's so warm though...I'm right there with JCleary. Although I took my chip off after it threw codes and shut me down, now the overhead went up about 1. 5mpg, but we'll see when I fill up. The overhead varies way to much to even be useful usually.
I guess I'm going to have to move to Hawaii. . low, near sea level alt, humid air and can't get much over 55mph anywhere so I'll finally get good mpg, hopefully. I know It'll be a sacrifice, but I'm willing to do it just for the mpg!![]()
