Hi Don -
... well I'll tell you what I know of so far - by that I mean I'm doing the last of the R&D and have already picked up some of the hardware, to include a '98 47RE core (w/o the od), a Dana 80 dually rear from an '02 Cummins 1-ton, the GearVendor, and I already have both donor trucks (the '93 Cummins club cab and the '85 crew cab). Oh yeah, I'm also long-winded but it's usually a good read
To start, the one, single, above all else item that is without a doubt (to me at least) the biggest influence on how well the truck behaves, is the transmission. I also like performance and I like to have it available when I want it, even in a big honkin' diesel. That said, the transmission is where the majority of the upgrades is going, and is also the biggest cost. In my case I'm building a very big and heavy rig, and most guys in here won't need all of the upgrades to the transmission that I'm getting, but I want mine to never frag itself. Towing seems to be the biggest strain on transmission's, even compared to drag racing, because it is the continued long hard pulling that'll eat a lesser transmission whereas a built one won't care what you put in front or behind it, so long as it's up to the task. Enter DTT.
When they asked me if I wanted 'good', 'better', or 'bulletproof', I said 'bulletproof' without flinching.
I know myself well enough, and I'm very honest about it, to know that when my rig is built I'll be going along up I-70 over the Rockies, hauling 10,000 lbs of trailer with an 8000 lb truck, and I can not stand wussing out on the hills - It almost physically hurts to have to slow down :-laf I'm gonna keep my foot in it, flames outta the stacks, smoke blowin' black as coal, cruising up a 7% passing Powerstrokes, going at least the speed limit regardless of what I have behind me :-laf That means BIG power and a kick-butt scary transmission with impressive guts, and a lock-up converter - period, which means 2nd gen transmission with all the bells and whistles. That cranks up the price but not so much that it'll keep you from upgrading, so there's that to consider as well. I figure it this way - if the transmission is no kidding coming out of the truck and getting upgraded, and there's ANY possibility that you'll crank the power eventually, go for the good stuff - then laugh all the way up the hill! Bulletproof translates into billet steel input shaft, main shaft, and output shaft, and XHD 3rd gear drum, to name the biggies.
Okay - next to consider - If I went out and slapped down $45,000 for a new Ram I'd still only have half the rig of what I'm building, and I'll also have half the cost of the new one, and for me that is too cool. So, for me, the cost of what I'm doing is constantly compared to the cost of anything new - the difference is that I get exactly what I want, it will be how I want it, and I'll know how to adjust all of it. I'm learning in the process, and for me that is half the fun!
Okay, that's some of the 'why' I'm doing all this, and here's some of the prices. As well, I have been budgeting for this project for years, all the while learning about and bombing my '93 and reading everything in the process so I have the best idea of what I'm doing, and I'm also sparing no expence - If ya do it once and do it right, ya never have to do it over!
My full-boggie DTT transmission will probably cost right around $6K. The rear axle right around $2700. The GearVendor was $2700. That right there is for bulletproof hardware that'll make Kenworth owners smile, and I can put any amount of hp and tq to it that I want - any. I can haul my 20,000 lbs-worth of toys all day with cool temps and no worries. It's all about the transmission. The rear Dana 80 was also a no-brainer, and it was actually very reasonable, and with it I got additional salad dressing like discs, ABS, lim slip, and 4. 10's, not to mention a scary towing capacity. The GearVendor is for (typically) unloaded 85 mph (or better) cruising, or for drag racing little imports... . or Corvettes. I'll also be able to split gears for big hills, though I'm not planning to need to do that much.
I think a standard DTT trans without the Unobtanium parts is right around $3500? That's really good, and really strong. I'll hopefully be pushing around 400 hp and 1000 tq, so I need the hard parts, but for most rigs that's not required, and I wouldn't sweat not having the high dollar stuff. The guys at DTT will hook you up and thay'll ask you everything about your rig - weight, application, use, power, gear ratio, all of it, and they'll tell you how much transmission you'll need. If the truck is mild I think a standard DTT trans will be great, and it will definitely be money well spent, and only once. I'm not sure how much installation is - labor is labor, but they've done a bunch of these.
The fromt Dana 60 dually axle I already had, but it's around $2000 all dressed up. The engine is getting a bunch of stuff to make some serious power, but that isn't 'necessary' for most.
I'd like to also add that I am not afraid of fabrication, at all. In fact I get off on it. The 2nd gen transmission swap is only a very small part of the work going onto the rig. I'm stripping the '93 down the bare frame - it's going to get stretched, sand-blasted and coated, then the chassis/suspension gets designed, built and installed, then the running gear goes in, then the body mods begin, then the interior, then all of the nitty gritty (fluids, electrical, hydraulics, pneumatics... ) (I'm making myself smile... . ) I can't wait to build this thing... .
But hey, I just want a big ole' truck that'll haul anything, anytime, anywhere, and that's how I'm a'gonna do it.
MAN, can I write a book or WHAT?!!
I'll be doing a full thread on the whole project - should start full tilt in about a month or so.
Hasta!
- Sam
