Details here: TDR Privileges
C-HAWK try putting the two worse out-of-round tires on the center axle this may smooth out the bounce. You may hve frame flexing once the trailer starts bouncing and thre tire bounce and the trailer flex match up to each other witch in our case happens to be at 62-68mph.
The tires should be hot before balancing. If they are flat spotted from sitting they will be balanced wrong. If you can find someone that has Hunter 9700 balancer you can measure road force variance and index the tires to the rim.
