Need some Help! SRW or DRW?
What is the max GCVW for a Dodge?
Any one install Reese 5 hitch???
OK here's the deal the wife and I are deciding on a new truck and 5'ver combo. I've been looking at a 3500 auto 3:73 srw, But she picked out a 38' fleetwood gear box, with a gvw of 11,100 dry and around 17,400 loaded, I'm thinking we'll be over the gcwr of a drw? I need some advice from those of you in the know. Thanks in advance
1) Don't even consider a SRW with that trailer. You will exceed the truck's GVWR before you even load it up.
2) Don't even think about 3. 73 gears with an auto for that trailer.
3) You will be at the limit for any 1 ton pickup truck with that trailer.
Good luck.
With that trailer, you will need the GVWR, rear axle GAWR and rear tire load ratings of a DRW. Even then, at 17,400 lbs trailer weight, you'll probably wind up like me with our 16,000 lb GVWR 5ver that Momma had to have - within my GAWRs, but we won't talk about the truck's GVW and GCW! :(
Rusty
I will third that. Like Rusty, you will probably be over the GCWR of the dually but at least you probably won't exceed the GVWR of the truck. I am very careful so I NEVER run overweight. :D
Casey
DRW for sure with that weight.
This 17,400 would include the fresh,black,& gray tanks full to capacity, that H2O gets pretty heavy, but you could adjust for that if you watch. I would go with the DRW/4. 10 like others stated. I have seen a few DRW's with the Western Hauler bed here lately an man are they nice looking rigs IMO. I've seen a 3G white one an two 3G silver one's an I liked them. :D
Tony
Thanks guys, I think I may try and talk her into the 33' gear box. This model goes 11,500 loaded and has a 2200# pin weight. I can live with the six shooter but I don't want the 4:10's I don't think I'll tow it enough for that gear set
I looked at these too but the 33 was not quite big enought for my needs and the 38 was too big- I really liked the features but they looked a little flimsey- the RV forums are showing a lot of delamination issues with the gearbox models- not trying to poo-poo just go in eyes wide open. You might want to ask about the delam warranty specifically and I personally would not buy one without an extended warranty to cover it. Too big an investment to rely on a one yr job.
This data is from Dodge's towing guide. Looks like you'll be overweight before you even get started.
2004 Ram Truck 3500 SLT/Laramie, Quad Cab, 4x2, Long Bed, Long Wheel Base, 6-Speed HD Manual w/Dual Rear Wheels, 5. 9L HO Cummins Turbo Diesel engine:
With 3. 73 Axle Ratio You Can Tow 13750 lbs2
Gross Vehicle Weight Rating (GVWR) = 11500 lbs
Payload = 4402 lbs1
Curb Weight = 7098 lbs
Curb Weight Front/Rear = 4089 / 3009 lbs
GAWR Front/Rear = 4740 / 9350 lbs
Gross Combination Weight Rating (GCWR) = 21000 lbs
With 4. 1 Axle Ratio You Can Tow 15750 lbs2
Payload = 4402 lbs1
Gross Combination Weight Rating (GCWR) = 23000 lbs
2004 Ram Truck 3500 SLT/Laramie, Quad Cab, 4x2, Long Bed, Long Wheel Base, 4-Spd. Automatic w/Dual Rear Wheels, 5. 9L HO Cummins Turbo Diesel engine:
With 3. 73 Axle Ratio You Can Tow 13900 lbs2
Payload = 4545 lbs1
Curb Weight = 6955 lbs
Curb Weight Front/Rear = 3960 / 2995 lbs
With 4. 1 Axle Ratio You Can Tow 15900 lbs2
Payload = 4545 lbs1
Fitter48093, you can see my 5er on my sig. This thing tips the scale at 11,700 empty. As it stands right now it's at nearly 13k. If you are deciding on a truck definitely get a DRW. The stability is way better than a SRW, plus if you have a blowout you have an extra tire to help out. Crosswinds won't effect you much with DRW as they will with a SRW.
Hate to say it, but that's why Ford has the F-450 and 550. Sure wish Dodge had a similar model, I'd buy one in a New York minute!!
Rusty
I'm so proud of you Rusty :D
RustyJC said:
Once a man gets used to it, crow doesn't taste that bad! :rolleyes: ;)
Rusty
Especially when your fellow dieselheads keep cooking it up and serving it to you in large portions. Oo.
Oh NO!! With the utterance of "HOG" I fear that the carefully avoided subject has been broached yet again! Shhhh! I hear the footsteps of the Weight Police! ;)
Dave
Heavy Dodge Truck
I heard a rumor that in Mexico Dodge Markets a 2 ton pickup truck that looks just like the USA trucks but tougher and rated higher. Not available in the states. Anyone else heard anything about this ? R C
trailer
Fitter48093, I have a dutchman 32 ft. SRV toy box. its 11,100 empty and has 14,400 gvw. with the wifes stuff and 2 harleys in the back it runs 13,800 lbs. was towing it with 91 W250. now I tow it with 05 3500 drw. 4x2 auto 3. 73 rear. check out the dutchman trailers. mine is holding up just fine I live in it all the time. it has 2 side outs. the wife will like it.
