New high Flow Airbox
CB Antennas - Do I need a "No Ground plane"?
Genos SS eyebrow fender trim
Any Word on this Doug?
Did you ever do this?
If not. What was the plan? If you did,, Where can we see it?
Thanks,
Merrick Cummings Jr
Originally posted by Cummins Corvette
If you make a GOOD box for the bhaf, that gets air from the fender opening and the scotty then put me down for one. I am buying one of the new ss malory mounts, but will always be willing to upgade for lower egt. An ideal setup would be one that just seals against the hood, fender, and firewall. That will be challenging with all the wires, ac lines and such. I plan on doing what I can to make this mount do that. There is also a gap between the fender and the firewall that would bring in more outside air if a sealing box was made. Let's do it! :D Oo. :D Oo. :D
Here is what I did with mine
Seals against the hood, and draws air from the slots in the hood, mainly the fender funnel, and a little past the PCM on the firewall. It could be completely sealed off from everything except the funnel, and still be open when you pop the hood. I designed this to keep out the water from splash back (condom got soaked during a 50 drive during the winter) and car washing.
