Well, 200k will be here in a month (upcoming work)... so I decided to do some preventative maintenance.
I've read about the idler pulley on the tensioner causing grief around this mileage... so I ordered one from Geno's, along with a new belt. Belts seem good for 100k.
Although I had replaced the water pump earlier this year, I decided to buy a second one to have on hand... just in case. I have read a couple posts that indicate the store-brand pumps don't hold well.
I bought new trackbar bushings from Geno's... trying to stiffen up the steering... also bought a steering stabilizer to replace the stocker. I'm trying to buy a dual shock mount for the front axle, there isn't quite enough control there for my taste, so I thought I might experiment!
I also need to change the spindle bearing on the passenger side of the DT kit... the seal must have failed at some point and water got into the bearing. I may actually need to replace the stub shaft as it might not polish up.
I also bought new wipers (yeah, whatever) and new headlight bulbs. I have found that, while these new fangled "lifetime" bulbs last a longtime, they tend to yellow over time from the elements (those little spring-like coils) melting together.
I've also got a new set of Revo IIs sitting in the shed for winter... not to mention the GCF needs changing...
And I have a few other odds and ends to do. This will make around $3k or so in fixes this year (including a Smarty Jr, Clutch, and full brake job). But the truck is paid for, so I guess that's not all that bad.
