We have a 2010 ram that came in to the shop, unplugged h&s mini max to access obd port and the scan tool will not connect, nor pull power from the port. When I check with test light I have power at pin 16. Tested grounds (signal and chassis) and they are good. Used a multimeter and only have 7.5 v at pin 16. Battery's tested good (over 910cca) and about 12.6v in each. No corrosion or splicing seen in wires. Tried another scan tool with no luck. H&s will communicate with the truck but I need to use scan too to diagnose other problems. Tested my scan tool on other tricks in shop and they connect fine. I am at a loss here has anyone else had this issue? My scan tool is a snap on verus pro. Any insight would be appreciated!
Thanks,
Matt
Thanks,
Matt
