Overload Springs
Hey Steve, Tell me about your front receiver...
Anyone lose their commercial insurance???
I have a 97 2500 4x4 it doesn't have the camper package. I installed a 2. 5 in rancho lift. I haul a 9ft 11 slide in and pull a 2 horse bumper pull. I would like to install OEM type overloads, I can't find a aftermarket supplier. DC is way to proud of their OEM springs and parts for the spring install. Can anyone help me with this matter. Kurt
I think helwig makes good springs, or you could try JC whitney. I can't personally say I have used them but heard of others that have and they were happy.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
I installed Hellwig overload springs.
My hitch weight is listed at 1650#. I haven't checked it. Upon hitching up, the rear of the truck would drop 3". After installing the overload springs the truck drops 1 1/2". I can raise the truck bed by putting more tension on the springs, but that would also stiffen the ride. I am thinking of lifting the bed the 1 1/2 inches to give a level ride when loaded. As it is, the ride is probably a little harder than stock, but not significantly. After all, it is a truck and will never ride like my Mark VIII.
Kurt:
I installed the Roadmaster Active Suspension and took the OEM over-load springs off. The truck has a more positive feel with less hop. The only thing I have noticed is the RAS system has to have a very good shock. It also is adjustable for more or less tension. It may not be for everyone but I have learned to like it.
I think I payed around $250. Good product.
Preston
96 3500, Black SLT, 5 speed, turbo diesel, , with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , Mag-hytec rear cover, dual-remote by-pass filters, and Roadmaster Active system
