2nd Gen Non-Engine/Transmission Pyro Probe Location
Where is your pyro probe located?
  • Pre-turbo
    Votes: 155 68.6%
  • Post-turbo
    Votes: 51 22.6%
  • Don't have an EGT gauge
    Votes: 20 8.8%
  • Total voters
    226
Engine/Transmission (1998.5 - 2002) Edge ez & DTT Valve Body
2nd Gen Non-Engine/Transmission How much have you spent on BOMGing?
Originally posted by Evan A. Beck
I'm just curious about this one... Where is everyone running their pyro probe? Before of after the turbo? I think it should always be in the manifold, but hey, thats just my opinion. :D
I had the same problem so off to talk to the big guys who fix the big one. The answer I got is. The probe cannot burn off and go through the turbo if it mounted after the Turbo :) Good Luck
A probe also cant burn off and go through a turbo PRE turbo either. If the temp gets hot enough to melt a probe, your turbo would be destroyed anyhow (Most likley your engine would be toast too). I spent 3 years working on $70,000 turbos mounted in diesel locomotives that all had probes PRE turbo.
Pre turbo and a gage you must absolutly have. I figured that anybody that didn't have one would have to be a Ford or Chev owner. Right behind that has to be a trans temp.
