Living in the northeast we see our fair share of snow/ice and road salt. Well I guess 14 years and 241,000 miles took their toll on my rear spring shackles. I was backing out of my driveway this morning to go to work and hear a loud bang. I sorta dismissed it as my parking brake maybe was hung up or the rear springs were frozen (as we had an ice storm last night).
Stop to get a cup of coffee and notice the truck is low on the driver side in the rear? I jump under the truck real quick, sorta expecting to see a broken leaf, but to my horror realize the rear spring shackle had ripped itself into two pieces because it had rusted to badly.
I immediately called my local Dodge dealer (Dick Greenfield Dodge, super cool 24hr parts/service M-F) and they had the shackles in stock. I'm guessing its somewhat common occurrence, otherwise why keep them in stock? Anyway, I bought 2 shackles (passenger side is in same bad shape), 4 new bolts, 4 new nuts for a grand total of $165 with tax:
Shackles PN 52038664AB (new bushings already pressed in) $47. 25 each
Bolt PN 6504782 $10. 20 each
Nut PN 6402252AA $4. 50 each
Surprisingly, I could have reused my old nuts and bolts as they came apart without much difficulty at all. I did have to drive the lower bolt out of the old bracket, but not too bad at all. Took me 1 hour to do the driver side, the passenger side can wait til the weekend or until the weather gets a little better. I used generous amounts of anti-sieze on the install and torqued the bolts to 210ft-lbs per the haynes manual.
The bolt head is a T-60 and the threaded end of the bolt has a hex headed shank which is 11mm, the nut is a 24mm. I picked up a T-60 at the store, but never needed it. Just a 24mm open end wrench and a 11mm on the shank end of the bolt and I was able to get things apart no problem. Once apart I jacked the truck up using the trailer hitch to get the spring/shackle and bracket all aligned, then tightened things up loosely. Got the truck back on the ground and proceeded to torque to spec. I'll take pics of the process one the passenger side, I was rushing to get this done and beat the weather tonight, so I can get to work tomorrow.
I was shocked I was able to get things apart so easily. Here's some pics of the shackle. Passenger side is identical, except its in one piece still, not three. Luckily i wasn't loaded with anything or towing. I'd imagine that would not have ended well.
Chris
Chris
