I guess that wouldn't be to expensive concidering your time and trouble from your experiance. I would do all six just for the piece of mind, I'm sure you don't want to go through it again. Will all of the pistons be of the same diameter/size? I wonder, because it would run slightly out of balance if there were a difference.
The one sleeve that is already installed is for a 20 thousandths piston and the other five are bored out for a 20 thousandths piston, so they would all be the same piston size.
