Thank you for all the help you guys offered me with my rough idle problem.
I did the oil in fuel and FCA replacement, but that was no help at all. The problem came to a head as I was towing my 5th wheel in Western WA.
I had justed crested a long climb hill and when the transmission shifted back into O/D, the dangest noise I have ever heard came from under the hood, I pulled over for a look see but I could not see any damage so I drove out of harms way and called for a Tow. I was towed to Tom Matson Dodge in Auburn where the problem was found. Two bolts securing the T/Converter had become very loose with one falling out and the other four where also pretty loose. These six bolts had blue loctite on the threads but it didn't even look like it held as there was a lot of loctite still in the threads.
All holes where cleaned and checked for being stripped as was the T/converter, all six bolts were replaced with new ones with blue loctite, Dodge says they should have red loctite, but the S/Advisor said that once you use it, the bolts are real tough to get out.
Now my truck runs very quite and smooth again, just like new, spool up and shifting is very crisp once again and I am a happy camper. Moral of this story is if you are having a rough idle problem, look at the T/converter bolt torque, it only takes a few minutes to get the inspection cover off & have a look see. Injecters aren't the only problem for a rough idle condition.
Thanks again,
Gary
