Smarty CR is ready.
Any need for a 1st Gen cold air filter?
Smarty 3G software update??
Marco,
Great job on the smarty. You have an impecable reputaion on the TDR. This is not criticism, so please don't take it that way. But what happened to the RPM's? Is it going to be an update at a later time? Is it even possible :confused: When I read that it was not a feature on the Smarty, I heard 3rd gen pullers hearts breaking.
Thanks in advance,
Steve
Marco/Bob, I heard the HP numbers were down when pulling the third shot off of the 04. 5 trucks and above. Will there be a setting to pull the third shot off for trucks that want fuel economy and less smoke? Also, level 0 says half power. Is that for trucks with huge injectors or is this a misprint, Thanks, Richard.
EXCELLANT! thats what a huge injector truck needs,oh man thats nice. See if Marco will let us pull the third shot off ... Thanks again Bob!
Would it be any advantage to have a reflash done of the ECM at the dealership before using smarty? Or should I just take by bully dog downloader to stock and then use smarty?
Bullydog's stock program
Or
Dodge stock program
Would there be an advantage to one or the other when programing smarty overtop?
as long as smarty can read your ecm information you should be good to go. If you have issues due to a BDDL and a check engine light then its a different situation.
Friday will mean...
For those who are getting CR SMARTYs on Friday, here is another meaning for SMARTY:
Shoulda Made an Appointment for a Rebuilt Transmission Yesterday! :-laf
S M A R T Y ! :-laf
hahahaha!!
I hope those that are getting them will play early and tell the rest of us how great they are!
Can't wait 'til 100k so I can play too!
S M A R T Y ! :-laf
hahahaha!!
Thats a good one... good thing I built my transmission last week.
Or
Dodge stock program
I had a Bully Dog Triple Dog that I traded away. I obviously had to return to stock before it would work for the person who is using it now.
Anyway, the Smarty downloaded and works great! Quick downloads, and loads more power than the BDDL.
Marco said:
I'd like to point out that the 03 produced 130Hp more @ 30 Psi of boost while the 04. 5 produced 170 hp more @ 40! Psi. Does that tell you something?
Marco
Hey call me stupid but I dont understand your point?
Are you saying that the 03's can't provide the fuel at higher boost levels and all we need is more fuel in the way of injectors and then will will be equal mod for mod.
Diesel power for beginners.
Add fuel, add air. Then add more fuel and more air... . Fuel alone is not enough, you need AIR to burn it. In all evidence 30 Psi is less air than 40 Psi.
Helps?
Marco
The way I read it, the 03's need to push more air, not fuel. IIRC, the 04. 5 has a higher wastegate setting than the 03-04 from the factory.
