Sop#4
Dodge Ram is victorious
What would YOU do?
Whatta you mean you need to eat? The last time I saw you..... :rolleyes:
Yeah, I won't go there! :-laf
OK, I got the message on the Knights Inn! :eek:
Bill, she won't stay in a tent, hence the problem! ;)
You's guys are going to be busy, like a one arm wall-paper hanger.
Remember, most of the guys will NEED to drive the thing home. It's tough to do with the top missing from a pump. :)
I am staying far out of town. I would recomment the BW above any in the area. I for one will be far to the East. I drive from that direction so little point to drive into Peru when the event, aka farm, is to the East of Peru.
I have thrucks washed and armor-all applied. Greased and oil changed. Carpet shampooed. Windows washed. I will drive the silver rig, the wife the other.
If I washed (and waxed the 3 spots of paint) on my pickup right now, they'd all be nasty by the time I got to SOP. :rolleyes: I'll do it after work the Thursday before the event. :-laf
I reset my timing the other day. Fiddling with the fuel filter and not getting in any hurry, it took me almost an hour. I also marked about 3 places on the pump flange so I can just move the pump to where it needs to be if I feel the need to change things.
Gov springs take about half an hour.
DP
I was thinking of making up some pointers for TDC ahead of time. And bring bolts too.
DP, I was thinking of marking different timing spots also! ;)
I saw there is a hotel in Logansport that's reasonable. I don't want to drive past where I need to go, then come back though. 1 nite at the BW is a tank of fuel. :eek: Or was last week, now it's part of a tank. #@$%!
Hi guys, I think I might be able to make it this year. I work that weekend ,but can get it off. If I make it down my brother will be with me. Would be great to meet you guys.
If there is any time maybe some help with my truck. I have a autometer tach that needs to go on and a gov spring. My KDP needs to be done so I would like to watch one being done.
Paul
Paul, wont make any guaratnees about the KDP, but we should be able to do either the spring or the tach calibration. Both if we get lucky.
PM me if you want timing done, and whether you have verified TDC or not. The FSM tells how to find TDC (valve drop method). Look under timing pin replacement, with head on, or something to that effect. ALso, if you plan to do timing, bring a fresh fuel filter, as it is MUCH easier to remove the filter and stick the dial indicator in the pump that way.
On both my 92. 5 and my 91. 0, the standard 1/8" above stock took me to over 2. 0mm. Just a thought.
DP
Page 13 boys! What's hyper-mode? I'm in that all the time! Oo. If you were there last year, you might have noticed this! :-laf
Fuel Injection Pump........???
Was I to bring along my training aid fuel pump? I have not heard. I know there will be some pump activity, so that may have to do.
What say you? I will simply show up empty handed and lend a hand if we don't need a pump mod/how to/theory of op. class.
Scott
BTW, I'll be around till monday noon to fix any mods or "repairs" that went awry on Saturday... ... ... ... ... ... ... ... ... ... ... ... ... ... ... . :-laf
