Died again. It was cold, -12, I plugged it in but the *#@ GFI was tripped and the timer never moved. It started with some throttle and a stall. Truck was idling fine for several minutes and died like the fuel was cut off. So I pop the hood and check the fuel gauge, it reads 20psi, and the fuel selenoid is up. Not really a fair test because of the low temeratures. I bought fuel from concord truck stop and did not add power services anti-gell. However, they must be running winter mix in concord nh now. I drained filter water seperator before I left. Funny thing is I had backed trailer in so front of truck was up with just under a 1/4 tank of fuel... Air leak strikes again. Or is it the injection pump going south? Truck is parked same way plugged in for four hours lets see if it dies again. Started truck, pressure was 25psi, dropped to as low as 6 shortly after starting and then slowly climbed to 15 and back to 25 psi. Truck did not die. I guess the p7100 can tolerate low fuel pressure. After the holidays I'll replace fuel lines from tank to strainer and return line. Thanks for all the input.
