Turbo Thom said:Oh, that's easy. You beat it to hard. That's always the answer.
DBazley said:CTD12v,
Sorry I don't.
I just know that I gave them the part # I got from my AllDataDIY parts list, and it was followed by 2 or 3 superceeded part numbers, so they keep updating it - which is not a guarantee of a 'stronger, improved part', but at least a suggestion.
I did examine it at the parts counter, my impression was that it's a well made, strong part. It had this advantage over my $$$ Borgeson shaft, it actually glides in & out smoothly. Rotational play was minimal - maybe 1 or 2 degrees - just enough to allow smooth operation.
It was only $ 155 at Carl Burger Dodge, La Mesa (San Diego), CA parts counter.
I just checked now, and they quoted me the same part # for your year truck you just gave, as well as the same price, $ 186 actually.
Maybe an online MOPAR parts source would help you with a better price ? Here's two:
www.ArcherDodge.com
www.MakeitMopar.com
They're sponsors at DodgeTalk.com and reputable.
If your splines are messed up, it may be your best option !
I wish you well,
David Bazley
ProspectorTim said:Update:
I took the bushing out yesterday. It took about a pound of dry ice, a big screwdriver and another pry bar - and a bucket of sweat - but I got it back out without pulling the column.
I hand-sanded the inside and the outside of the bushing until I could push it almost all the way in without ANY hammering. When I was happy with the fit, I sprayed it inside and out with Amsoil Heavy Duty Metal Protector and re-installed it. A couple of LIGHT TAPS with the ratchet handle sent it in the last 1/4". It drives SO much easier now! If you ever had a power-steering belt break and had to drive a week before getting a new belt - that is the best comparison of my recent experience, except this was worse.
I think someone already mentioned this before, but I'll point it out again anyhow.
WD-40 is NOT a lubricant. WD stands for Water Displacement. It also cleans and protects metal and loosens rust, but it is not a lubricant. Well, I go to reading the can (I do that every now and then), and the same can be said for Amsoil Metal Protector. It is everything BUT a lubricant. However, Amsoil Heavy Duty Metal Protector IS a lubricant.
I keep both kinds in my shop, but you can be sure I'll grab the RIGHT can for the project from now on. LOL
