Still leaking from under the KSB solenoid.
Warped brake rotors??
250 to 350 susp.
Well, I finally got around to putting the KSB solenoid back on. It was leaking from where it joins the pump body, right at the bottom. I filed the mating surface on the KSB flat, since it wasen't perfect, put in a new green O-ring from Bosch, bolted it together with new bolts, started it up, and it still leaks. :{
I can see it good with a light and a mirror, and am 98% sure it is coming from the joint between the KSB and the pump, and not from the cover on the block side of the pump.
Any ideas? Could there be a crack? What to do next? Will I have to pull the pump?
I have reveiwed the directions for pulling the pump and I don't see a problem except for the part about "barring" the motor over to line up the TDC pin. Looks like thats a special tool that I don't have - to insert into the bellhousing and turn the motor. Any other way to do it?
BTW, I advanced the timing 1/8" today while I was fooling with it. After I loostend the nuts, I used a porta-power hydraulic ram between the battery tray and the top braket on the pump to push and hold it in the right position while I tightend the nuts. Worked pretty slick!
Joel
To turn your engine to TDC without a barring tool you can put a socket on the alternator pulley and turn the engine backwards, the belt will slip if you try to turn it forwards.
If you had a manual trans you could put it in gear and push it.
Sorry don't have any ideas on your leak.
Happy Rammin,
Caleb
Joel,
The casting of the KSB 'can' crack. I't doesn't seem to happen alot, but it is after all, only cast aluminum.
The timing piston and a couple fuel passages are in the KSB, one is an "excess pressure" relief passage. It may be that you have a crack that opens just a tad when pressurized during operation.
Hmmmmm... . any thoughts on how to diagnose this possibility???
Guys... ... ... ...
pb...
Thanks for the replys.
It's a pretty big leak about one big drip every second when it is idling. Not just a little seepage where I would have to wonder where it is from.
Maybe I should take the KSB off again and bring it to a shop that has zyglo? or some kind of magnaflux type sysem for aluminum to check it for a crack. No crack was visible to the naked eye, but that was with no pressure on it.
