Strange electrical issue
Right hand tie rod end
sport conversion wiring
To remove the connector, you first have to unlock the tab holding the black cam-lock lever. Then pull the lever down which will pull the connector partially out.
To install the connector, push it into the module and push the black lever up, pulling the connector into the module, until the lock tab snaps in place.
Yeah once you understand how it works, this is by far my favorite design. Having that lever makes things so much easier, wish they all worked that way.
