And the end port feeds 1 and 6=
RacinDuallie said:I'm porting this head to flow more for max h. p. for street use..... I wonder how those huge ports you have there would affect spool up on the street? Drivability must not be an issue there, Greg you said you get towed to the line and towed back to pit after run right?
Diesel Freak said:WOW this is a cool thread!!!
Too bad my G. I. Bill cant support my Diesel Addiction!!!!
COMP461 said:The intent is to make the port as big volumes as possible. I believe if you had 400 or even 500 CFM air flow you could still drive it, and it would be as tame as the fuel system. As far as spool, I believe it will spool quicker, and smother, I am going to loose a lot of boost numbers, but gain total air flow, I am even considering running a single using the BB
Cylinder #1 has an obstruction of the intake port caused by a casting boss for accessory mounting bolt placement plus a forward facing valve port which causes the intake air to run a maze to reach the cylinder. These reduce the airflow to the #1 cylinder, causing it to run richer than the other cylinders. Often, the exhaust manifold gasket has been cooked on cyl #1, while the others are fine.
RacinDuallie said:And my intent is to show what could be done and still drive down to the local store for some milk- and have reliable power to go to the track, without worrying about thinning out the casting so much that it'll lead to your head cracking- the last time I checked you only drive Dr. P's truck 1320' at a time so I don't think you'll be heading out for milk anytime soon... .....
aharrow said:Hey Duallie I thought this was the max h. p. thread not the streetable milk getter thread will you please make up your mind are you looking for the maximum h. p. or the streetable h. p. just wanting to know thanks Aaron![]()
DieselMinded said:Ted Jannetty
Jannetty Racing Enterprises Inc.
You guys say CLY. 6 also runs hot . . why couldnt you run 6 Small airhorns one to each cylinder ??
DM
