Maybe this will help
#8 (permalink)
tkerrigan
Online
Send a message via Skype™ to tkerrigan
Videos
Here, I did it for you.
2 links from elsewhere to this Post. Click to view. #1 (permalink)
F-15I Ra'am
Offline
Thumbs up One Piece Driveshaft
Guess I get to be the test-mule for this. Just installed a one piece drive shaft for an 08' Megacab on my 06' 4x4,auto,Megacab. Truck has a little over 92k on it and was about due for u-joints. Figured I'd eliminate one u-joint and the carrier bearing. Part# 52123220-AB list: $602, got it for: $430 plus shipping from MOPAR4LESS. Tools needed: ratchet, couple extensions, 15mm socket, cheater- pipe. Make sure to block your tires. Also remove {4 bolts} and leave off the bracket that holds the carrier bearing to the frame. Took it out on the highway, hit the speed limiter a couple of times { Smarty Jr. on level 2 }. Everything is fine! Gotta haul some calves to Dalhart or Clovis in the next couple of weeks. I will keep everyone posted on it.
__________________
04'3500,SLT,4x4,QC,SB,H. O. ,48re,Almond,Quad Race, AFE Stage1,X-Monitor,Bank's Monster Exhaust,B&W hitch,RanchHand rear bumper
__________________
Tom Kerrigan
Oct '90 thru Aug '04 '91 W250 5SP
Aug 04 2004. 5 4WD SRW QC LB 6SP 3. 73 Almond Pearl Laramie, Rhino liner, Lund running boards, Buckstops, B&W gooseneck & 5wh hitch, B&D exhaust brake, Dtrac freespin kit, air bags w/pump
Member TDR '96 thru '02, Again in '03.
