Based on what most driveline builders say it is not heavy enough for a diesel application. Even the larger aluminum DS's are border line if you have a lot of TQ.
Doesn't every Ram after 07' Run a one piece aluminum????
hhhmmmm i have not seen one guy on any forum have a problem with em. Im heading for my 3rd carrier bearing in 4 years at $200 a pop by the time its pressed on. This **** getting old.Stock power it is probably ok if you are not towing heavy. Towing is another whole animal because you get into axle wrap trying to start out and it is easy to ding and inadequate DS. AFAIK, factory is a steel DS, especially on these longbeds.
Update: Bought the 1-piece aluminum shaft from Drive Shaft Power. $703 total and free shipping. Is made to order so that took 5 days but shipping was only 2 days. Is OEM spec but 0.125 thick instead of 0.85(OEM) and comes with Spicer U-joints although stock size. Seems well built. Truck drives nice and smooth now and quiet. My carrier bearing was shot again for the 3rd time in 85k miles. Glad to be done with that piece of crap 2 piece shaft. Anyone want to buy my old one????
Correct. Ive read the OEM one from dodge are 0.85 thick tubing.
Huge difference in 0.85” and 0.085”. You have said 0.85” twice.
If the OEM was 0.85”, seems too thick, and you got a 0.125” the new one is much thinner.
I've had mine for about 2-3 years . I got tired of changing out carrier bearings. Driveshaft King in Dallas made it for me and I had it the next day . 700 dollars . I would highly recommend them . I might add that I pull my mini excavator (10,000) lbs on my trailer approx . 4,000 lbs. with no problem .Before ordering one online check with your dealership parts department... List price from Dodge is $696. 90 but they'll let them go for $552. 00. I've seen them online from $490 to $570 and that does not include the $50 to $65 shipping charge. I just ordered one today... . I'll have it Monday along with about $50 more in my pocket Oo.
Drive shaft king is the best is the businessI've had mine for about 2-3 years . I got tired of changing out carrier bearings. Driveshaft King in Dallas made it for me and I had it the next day . 700 dollars . I would highly recommend them . I might add that I pull my mini excavator (10,000) lbs on my trailer approx . 4,000 lbs. with no problem .
