Timing Cover Question
AIRHEAD ATTACK........Left the key on
2001 3500 Fuel Mileage Update
A quick question to those who have pulled their timing cover. I have the new gasket and crankshaft seal ready to fix my dowel pin but It doesn't say in my service manual whether or not you need to use sealant on the gasket. It does call for Loctite 277 on the crankshaft seal. The gasket is a hard material, not rubber. Answer from anyone who has done this already? Thanks.....
My 2 cents Throw away the gasket,Or apply clear bath-tub sealent to both both side's .
If you throw out the gasket use the 600 deg oranage gasket maker sealent. works just fine.
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
750,000 miles
My friend at the dealership likes to use the spray on Mopar sealer (kinda like Permatex). He puts Loctite on the cover and outside of the seal when installing a new seal.
