Transmission Pan Gasket for Mag Hytec Deep Pan
Dirty fuel anyone?
transmission Rebuild Went BAD, Why, Help ! ?
MSkyrman
Could someone tell me if the reusable Mopar trans pan gasket is compatible with the Mag Hytec Deep Pan? Or, do I need to use a fiber gasket? I am changing the fluid and filter on the tranmission for the first time and I'm not sure what gasket would be best for the job.
I made a mistake and used the fiber gasket isntead of the Mopar reusable gasket. The fiber gasket seeps fluid and makes a mess on the MagHytec pan. I saved the original reusable gasket and will reuse it the next time I have the pan off.
Bill
Same here. I used the original reusable and the fiber one went in the trash.
Some clown argued with me on another forum that the fiber gasket that comes with the pan is a much better gasket. Said he always throws the OEM gasket away on all the mag-hytec pan installs he's done.
1 out of 100 will leak with the oem gasket. On the otherhand I have never had
the included gasket leak on any of the hundreds of Mags... ... . I have installed. Haven't seen a cork gasket in years :-laf thank god
