Hello everyone.
I have the Bully setup and need some advice here. Today when the compressor kicked on to fill the tank it must have ran for about 5 minutes and would not cut off. I pulled over and took the fuse out and checked pressure in the tank and it was about 115 PSI. did not seem to be pumping any air. The compressor head was not hot either. I just didn't want it running without pumping air. The unit is still under warranty(about 7 mos. left). I will attempt to check it out tomorrow,I don't think it has any leaks otherwise the tank would not hold pressure. Other than that it seems OK. Any tips would be great.
Regards,
Phil
`01 2500,4x4,QC,LB,ETC,DDX,DHG
3. 55 LSD,Tow Pkg. ,Snow plow pkg. ,Forest Green PC,Mopar alum. side steps,Mopar mud flaps with Cummins logo,Mist grey seat covers,Tekonsha brake controller,Hadley air horns,Pacbrake.
Built in St. Louis
THE BIG GREEN MACHINE
Phil Stuart
Regards,
Phil
Built in St. Louis
Phil Stuart
