Troubleshooting Hadley air horns
Happy Holidays and Thank You
Aftermarket front bumpers, do they help?
Hello everyone.
I have the Bully setup and need some advice here. Today when the compressor kicked on to fill the tank it must have ran for about 5 minutes and would not cut off. I pulled over and took the fuse out and checked pressure in the tank and it was about 115 PSI. did not seem to be pumping any air. The compressor head was not hot either. I just didn't want it running without pumping air. The unit is still under warranty(about 7 mos. left). I will attempt to check it out tomorrow,I don't think it has any leaks otherwise the tank would not hold pressure. Other than that it seems OK. Any tips would be great.
Regards,
Phil
`01 2500,4x4,QC,LB,ETC,DDX,DHG
3. 55 LSD,Tow Pkg. ,Snow plow pkg. ,Forest Green PC,Mopar alum. side steps,Mopar mud flaps with Cummins logo,Mist grey seat covers,Tekonsha brake controller,Hadley air horns,Pacbrake.
Built in St. Louis
THE BIG GREEN MACHINE
Phil Stuart
My compressor will not shut off until it has built up almost 130# of pressure. The instructions tell us not to let the compressor run more that 7 minutes then it must have a 30 minute cool down.
Check for leaks with soap suds.
In one of the Grover post someone else had another way of checking for leaks. OH here is the tread!
https://www.turbodieselregister.com/ubb//Forum3/HTML/001971.html
Hope this helps.
<font color=blue>"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Pro-flap mud flaps with Stainless Cummins "C" add to rear flaps, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, HOT Power Edge, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), 285/75R16 Cooper A/T's, Navigator 55w backup lights. </font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9265455" TARGET=_blank><font color=red>My 99 Dodge Cummins</A></font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9815423" TARGET=_blank><font color=green>BD Dyno Days 10/28/00</A></font>
<font color=purple>
Things to come; The clutch has let me know it is going to need attention very soon!
Pyro, 50# Boost and Fuel Pressure gauges (have Ultra lites will install shortly), PE EZ timing module and injectors (have Bully Dog step III injectors ordered), have 2 KC Daylighters (Stainless with 385,000 candlepower each), have 2 KC Fog lamps(Stainless 100w each) and waiting for Smittybilt Stainless Outland Brush Guard to arrive, then will mount guard and lights.
NRA Life Member! (Need to protect our rights and FREEDOM!!)<font size=-2>
[This message has been edited by BIG BOB (edited 12-20-2000). ]
BIG BOB,
thank's for the input. Put some soap suds on all the fittings and found only one spot at the schrader valve/pressure switch cross. Very small leak,but nonetheless I tightened the fitting. Put fuse back in,bled air from tank down to about 100-110 PSI,took only about 30 seconds or so for the comp. to build back up to around 130 PSI. looks good to me. Oh I did read the thread on the Grovers. Thanks again Bob #ad
Regards,
Phil
Phil,
Glad you got your Bullys fixed. They are truly Awesome horns.
I was driving beside a school bus today, some of the kids were waving so I gave them a blast! They loved it and the kids that didn't know or see me beside them kept looking for a 18 Wheeler! It was great!
Also today I was at one of my suppliers and was talking to him about my truck and air horns. When I left, he was on the phone, but I had to give him a blast! He jumped they startled him soooooo bad!
Have fun with them, you'll appreciate them more every day!
Bob
I was looking for some web sites on these air horns ya'll are talking about and haven't found anthing, can ya'll put some links on here, and what kind of prices i can expect
2001 3/4 ton driftwood 24 valve HO 6 speed; straight piped
Jason
