Famous TSB 18-019-01
Cummins High Idle feature enabled?
Cold idle engine warming.
This bulletin involves selectively erasing and reprogramming the Engine Control Module with new software. This bulletin applies to all Ram trucks built after December 17, 1997 equipped with the 24-valve 5. 9L Cummins diesel engine.
Extended idle operation, especially in cold weather, can allow varnishes/oils to condense on the exhaust valve stems, leading to stuck valves, and damaged valve train components. The repair procedure involves calibration software that will activate when certain parameters are met, reducing the chance of valve sticking as well as improving cab heat warm-up time. Idle speed will slowly ramp up from 800 rpm to 1200 rpm when all of the following conditions are met:
* Intake Manifold Temperature less than 60°C (32°F)
* Coolant Temp is less than 60°C (140°F)
* The transmission is in Neutral or Park
* The Service Brake pedal is not depressed
* Throttle = 0%
* Vehicle Speed = 0 mph
If intake manifold temperature (IMT) is less than -9°C (15°F), three of the cylinders will be shut off upon reaching 1200 rpm, creating a slight change in engine sound which is normal. Thus the engine has to work to overcome the three “dead” cylinders. This allows the engine to create increased heat in the cooling system, allowing more rapid warm up.
Either feature will abort when any one of the following occurs:
* The automatic transmission is placed in gear (forward or reverse)
* The service brake pedal is depressed
* Throttle position is greater than 0%
* Vehicle speed greater than 0 mph
* Coolant temperature is greater than 79°C (175°F)
