Ozymandias
RaceMe is the new brand name for the Smarty tuner.
Ron, I am not sure if John put a boost fooler option or not or if one is needed, but I have that option install on my Smarty. An I would recommend a boost gage with a EGT gage to be installed on your truck. I am using them along with a transmission temp gage. When towing my 5ER I can see between 30 and 35 PSI boost pressure even on slight grades with EGT’s around 900F in 5TH gear doing 65 MPH. When in 6th gear the engine could be around 1100 to 1200 F, with the boost pressure could be around 20 or 25 PSI, so I will down shift to 5th gear to keep the EGT’s down.
The Smarty is set on CaTCHER 3 with all parameters set to normal.
just a suggestion.
just a suggestion.
