Two tires down two to go
gooseneck hitch adapter`
Commercial hauler needs advice on backhauls
Well I have now lost two Goodyear Wrangler tires on my 5er in the last month. These tires are only two years old and have 97% tread life on them. Sidewall on both tires started bulging out. The tires seem to be separating inside and filling a portion of the sidewall with air.
Mike
What version of Badyears are going bad on you? What size and load range?
Goodyear had a "silent" recall going on with some trailer tires around 97 or so, but they replaced the tire with a new version which has a "S" on it.
Mike
Re: Re: Two tires down two to go
I went through a similar drill this July with Goodyear ST225/75R15D tires. First went flat with a pop, two days later a second lost entire tread and really fragmented, each while going down interstates at 55-65 mph. Replaced with tires having the "S" and have subsequently towed some 3000 miles without further problem. Old tires were of unknown age but little worn on a used RV recently purchased.
figures, these are the same Badyears I got on my Terry. Only I think mine are 205/75/16 E's. I will have to keep an even closer eye on them!
I hate Badyears, I had 5 orginal RT's on my 98 get bubbles in the sidewall. Sure they adjust them, but it still cost more then there worth!
Ok they are Goodyear Wrangler HT m+s LT225/75R16 with a load range E
Went to my local tire store today and they contacted Goodyear. Goodyear decided to do an adjustment on all four of my tires. The good part is that I do not have to replace them with Goodyear’s. I am getting Michelins 10 ply steel ribbed tires put on instead. I have to pay $40. 00 per tire, but to me that’s well worth it.
Mike
I am also looking at putting the Michelin XPS ribbed tires on my 5er. I had General Ameri 550's on and had 2 of them come apart at different times. I was thinking of changing from 215x85Rx16 to 235's - if I can do it with the same wheels. Anyone with any experience with these tires? or other recommendations?
Thanks!
I just checked tonight, I have 215/85-16 Load range E goodyear WT's I always keep my eye on them anyway. Sure would hate to see the RF one go, there is a bunch of soft copper pipes in the wheel well that have propain in them! I have read several complaints to the NSTB about trying to get Fleetwood to recall this setup!
