Used truck to purchase low miles But.......
Unusual “squealing” noise on deceleration
New 2019 or 2020
Well everyone I pulled the trigger on a 2018 dually , Aisin , 4:10 gears. 14k miles . private party . I was praying to God to give me wisdom and you guys were the wisdom. This will be my last truck (sounds weird saying that) . It's 4wd too . My first . Thank you all again
Congratulations. Kind of hard to tell for sure from the picture but looks like it might have air suspension also, does it?
Well everyone I pulled the trigger on a 2018 dually , Aisin , 4:10 gears. 14k miles . private party . I was praying to God to give me wisdom and you guys were the wisdom. This will be my last truck (sounds weird saying that) . It's 4wd too . My first . Thank you all again View attachment 124760
Nice ride!
If you don’t mind publicly posting the entire VIN, I can post up the window sticker and build sheet links for you.
lpennock it does not . He did remove a few of the spacers which he is handing off to me. It is a bit of a rough ride empty will need to get used to that. Thank you
gs Thank you I had already done all that . Got really good at that.
Scroll through the EVIC and check your pressures. That truck will need 80 psi front all the time, and one can vary between 35 psi empty to 65 psi loaded on all the rears. Might help some with the ride.....depending on where they’re set at now.
Thanks Dieselshadow. GS yes I guess it's close . Is Geno's garage the best place to buy everything? So if you do your own service on the truck how is the best way to document for warranty purposes? do I need to add anymore fuel filtration or did FCA finally do it right? thanks
Just order the supplies from Geno's and save the receipts. Document somewhere the dates and mileage of the services and you will be fine. No need to add any further filtration.
While not necessary, it helps if you get Oil Filer Plug (Lisle 57180 or similar). Unlike your earlier truck where the filter comes out the bottom of the truck, on this one it comes out the access hole in the fender liner. Having the plug stops you spilling oil when you put it on its side to get it out. Another option is just drop the filter in a ziplock bag.
For sure on changing the rear pressure. Question on the puck system ill be using the center hole with my B&W. Wheres the latch to lock the ball?
