Want to add a hitch off the back of my trailer
Need advice hauling a 26 foot gooseneck from ND to PA
towing double ignorance
I want to add a hitch off the back of my trailer. Not for towing, but to put a rack back there to hold a generator and fire wood. I've seen it done a bunch but don't know where to start looking for the rack. Any ideas or web links to places that make these or are the a totally custom job?
I had a 2" x 6" steel tube welded (and bolted for security) to my trailer frame. Then welded on a 2" receiver (and bolted). I also had to add a receiver extension which was also welded and gusseted. Works good for my bike rack.
Harold
Just be sure whatever you do its strong enough for what you intend to haul on it. Hitches on trailers are usually a custom install. If you have it made go to a quality welding /fab shop and tell them how much weight and how far away from the rear of the trailer you intend to go. Racks can be found at a number of places. Motorcycle/atv catalogs, camping world etc...
Thanks guys. I don't plan on putting anything heavy back there. 3000W generator and some firewood. I looked at the bolt on one from Camping World. But need the rack that goes with it. All they carry is bike racks. Unless they're called something else other then a rack.
I have a Hidden Hitch 82201 Model on our fifthwheel. We do not use it to tow - it is used for a bike rack. There are 2 different models depending on the frame rail width of the trailer. You can check the two types out here. I don't know if this is the best price though.
http://www.hitchmart.com/$spindb. !query. access2-2. hitchview. MOTORHOME~20HITCH
A 3000 watt generator is heavy. Be very careful. The hitch receivers are designed to pull a load, not lift it.
