Nope! - He don't need no stinking screen!
So, what cause the screen to be plugged?
Good to see yours clean. You do not know without checking. Your not putting it back in tho, right ?
You PS might work even better after your second flush and fill. Mine did on the 1999
Michael
I just installed the Cummins 180* t-stat and installed my oem Mopar fan clutch. I just did a quick shake down run to burp the system and the t-stat seems way more stable than the Napa. This was just a light duty cruise, I will know more as soon as I can load it up.
/QUOTE]
There was a guy here pulling containers with a couple 3rd Gens. Haven't noticed a Chevy. It's pretty rare to see a hotshotter running GM around here.I talked to a hotshot trucker at the form yard, he had a 40' 3 axle dually custom built trailer, towing it with an SRW Chevy. He had a load of form returns, 34K and said it runs 90 mph with that load like it is not thereI think he is using v-power...
The trailer has sliding axles and a hydraulic neck that will lift 4-5 feet, he can haul containers. The hydraulics was powered with a gas engine, nice trailer, he said he built it. He is from Wickenburg, Tom.
$318.00
I know it is winter but....I installed a 10" electric auxiliary cooling fan right behind the blockage of the front license plate area of the bumper. I have just on an on/off switch.
$318.00. I hope it works out for you it definately looks like it will move some air.
If you mount it backwards it will help when backing a heavy load.I hope it works too. Even if I get a 5* drop it will be worth it. I just hope the fan clutch is up to the task and the cooling system stack will allow the air flow it will need.
It looks just like my Cummins 20" x 10 blade fan on my Ford conversion. It moves a lot of air and it turns at crank speed, direct drive unit. Dodge turns at about 1.35 times crank speed so I am thinking it will provide thrust like an airplane![]()
What mileage was the first drain and fill done for the front axle?Changed my front axle oil and installed a drain plug. I went with 1/4 NPT. I am a little lazy about changing it so this will jump start me. All my other boxes get changed every 36k miles but the front axle I have only changed twice![]()
