What's the VIN # for HO CTD?
Who Makes The Best Exhaust Brake?
Bio die
I'm looking at 04. 5- 05 truck and know that i can tell if its an HO engine by the VIN #. What letter or number in what spot of the VIN means its a HO with a 48RE? Its easier to call a dealer and ask for a VIN # then it is to drive out there and find out its the wrong truck.
A little more specific, read the engine data plate which is actually a white decal stuck on the driver's side of the valve cover. It will list horsepower rating for that engine.
I know to look on the engine if im actually there but i dont want to drive 100 miles to look at a truck thats listed as a 2004 and find ou its a 2004 and not a 2004. 5. if i just call the dealer, then i can get the VIN # and know what engine it has.
After much hard looking:
the 8th position in the vin has to be a c for the HO engine.
POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin 1 = Manufactured By DaimlerChrysler Corporation
... ... ... ... ... ... ... ..... 3 = Manufactured By DaimlerChrysler De Mexico
2 Make D = Dodge
3 Vehicle Type 2 = Incomplete with Side Airbag
... ... ... ... ... ... ... 3 = Truck with Side Airbag
... ... ... ... ... ... ... 6 = Incomplete Less Side Airbag
... ... ... ... ... ... ... 7 = Truck Less Side Airbag
4 Gross Vehicle Weight Rating G = 5,001-6000 lbs.
... ... ... ... ... ... ... ... ... ... ... ... ... . H = 6,001-7,000 lbs.
... ... ... ... ... ... ... ... ... ... ... ... ... . J = 7,001-8,000 lbs.
... ... ... ... ... ... ... ... ... ... ... ... ... . K = 8,001-9,000 lbs.
... ... ... ... ... ... ... ... ... ... ... ... ... . L = 9,001-10,000 lbs.
... ... ... ... ... ... ... ... ... ... ... ... ... . M = 10,001-14,000 lbs.
... ... ... ... ... ... ... ... ... ... ... ... ... . W = Buses/Incomplete Vehicles with Hydraulic Brakes
5 Vehicle Line A = Ram Pickup 4X2
... ... ... ... ... ... . U = Ram Pickup 4X4
... ... ... ... ... ... . N = Ram Pickup 4X2 DX Family
6 Series 1 = 1500
... ... ... ... 2 = 2500
... ... ... ... 3 = 3500 Less Dual Rear Wheels
... ... ... ... 4 = 3500 With Dual Rear Wheels
... ... ... ... 5 = 4000 DX Family
7 Body Style 6 = Conventional Cab/Cab Chassis
... ... ... ... ... ... 8 = Quad Cab Full Rear Doors
8 Engine K = 3. 7L 6 cyl. MPI Gasoline
... ... ... ... N = 4. 7L 8 cyl. MPI Gasoline
... ... ... ... D = 5. 7L 8 cyl. SMPI Gasoline
... ... ... ... 6 = 5. 9L 6 cyl. Turbo Diesel 24v
... ... ... ... C = 5. 9L 6 cyl. Turbo Diesel High Output
9 Check Digit 0 through 9 or X
10 Model Year 4 = 2004
11 Plant Location S = Dodge City
... ... ... ... ... ... ... ... G = Saltillo
... ... ... ... ... ... ... ... J = St. Louis (North)
12 thru 17 Vehicle Build Sequence
