Where can I get a class V titan for my 3500
Hydraulic Brake Pressure Sensor
Towing Weights
I want to put a class v titan on my truck but todate have not found one on the web that list my truck.
Who has a dodge 3500 4x4 1999 with a titain on it the wts I want are or more. 2 inch receiver
1200 tounge wt
12000 wt distribution towing
I want to take of the DC hitch and bolt the titan in the same holes is that possible.
please post your experience
thanks
Curt
PN 45010 99- Present Rams
I've got this one on my 01 3500. I got it from a place down in Texas. I didn't have to drill any holes, the layout does make using the factory wire harness a bit difficult. Forgot the weight specs > weight carrying 1200/12,000 weight dist 1700/14,000. I found the receipt> 1-800-841-4661/ Discount Hitch & Truck Acces, Doug Calloway.
AL
Isn't the Titan a 2. 5" receiver.
I installed the Putnam Class V XDR. It has a 2" receiver which explains it's lower weight carrying numbers 1200 tongue/10000 trailer. It's weight dist. numbers are 1700 tongue/14,000 trailer. The hitch installs easily and looks much nicer tucked up under the truck than the factory hitch. I paid $160 for mine.
-Ryan
Cooker is right, the Reese Titan V hitch is 2. 5". This hitch can be purchased at Camping World.
I purchased a Draw-Tite class V hitch to replace the factory class 3 hitch and sent the receipt to Dodge and got reimbursed for the hitch and labor. I did have to return the broken factory hitch to the dealer.
I don't know it it is 2 or 2 1/2". I did not know there were 2 different sizes. I use my equalizer hitch in it as well as other hitches. I believe it is 12K cap. without the equalizer bars and 14k with them. I believe it also bolted up to the factory mounting holes. I got it at Joe's Hitch and Trailer in Dallas.
2" or 2.5"?
I believe the Reese Titan V is the only class 5 hitch that has the 2. 5" receiver... all others are 2". Also noteworthy is the Tork Lift hitch is of a double 2" (patented) design. Both of the "stacked" receivers are used simultaneously when a hitch extension is utilized. IMO, this is the best hitch on the market when an extension is necessary (even though I have a Reese Titan V). As you might have suspected, the double extensions are purchased from Tork Lift and are available in varying lengths.
If anybody with the Reese Titan V needs the hitch extension, email me... I have one sitting in my garage collecting dust ever since I upgraded to the Torklift setup...
Rob
I found the best deal on my Titan V hitch from the Lance camper dealer a ways from me. Apparantly Lance and Reese have a deal worked out that allows the Lance dealers to get them cheaper. I purchased the hitch, the adapter to allow regular 2" ball mounts, the extension bar, the safety chains, and the extension harness for the trailer lights all for $450 installed. I couldn't find even the parts for that cheap, much less installed.
Jerry
I've got the titan on my 2001. 5 3500 chassis cab. The rear 4 bolts all went in, but the front two I had to drill.
Great hitch.
I bought my Titan from my local trailer shop. Almost bought it from
http://www.reesehitch.com/
http://www.reesehitch.com/cl_5titan.html
They have a decent price.
But my local shop was the same price, no shipping.
I have ordered other things from the site above, never had a problem.
Great Hitch, went on easy. Use a floor jack and you can easily do it yourself. I did not need to drill a single hole. It was completely a bolt in job.
If you do order it, order the 2" - 2. 5" sleeve adapter... if you already have the tow bars you need...
If you don't you can order 2. 5" tow bars from the site above too.
I'm using a Draw Tight WD system with the Titan hitch, and I use the reducer sleeve. Tows great.
Bob
