Engine/Transmission (1998.5 - 2002) '01 DTT won't shift, where to look next?
Engine/Transmission (1994 - 1998) transfer case ?
Engine/Transmission (1994 - 1998) Which Alternator?
All, my truck randomly won't shift out of first gear. I have to pull over, shift in and out of nuetral, and eventually it will shift into 2nd. The problem is getting worse and worse, and I've notice when coming to a stop it won't downshift to 2nd/1st sometimes either.
Both Governor solenoids have been recently replaced as suggested by others. I also just installed a new TIMBO APPS in last night and the problem still exists... where do I look next?
Some say i might have a loose wire? If yes, when I get underneath the hood tomorrow which wires to I look at/trace from the computer to the trans?
The truck has both the ATS fix and a DTT noise filter installed to deal with the TC lock/unlock issue.
Is there some basic troubleshooting I can do with a multimeter on some of these wires that might be causing the problem?
Codes are:
0622
1765
1693
1740
1757
Any ideas?
I'm pretty sure the speed sensor was changed along with the Governor Solenoids but I'll change it again since it's so cheap.
Will a bad speed sensor cause my symptoms?
Anything else to look for?
Thanks
When I have used a ohmmeter on a bad sensor it would show open, a good sensor would show 600 ohms.
Dave
