2nd Gen Non-Engine/Transmission A/C Low side service port???
Because of various symptoms pointing to a sightly low charge I figured to add some refrigerant. Well Hmmm where is the low side port?
I see a port in the high side gas line, a port in the high side liquid
line, but none in the suction line.
Should I use the low pressure switch connection?
That is beginning to look like the only answer, short of taking it to a shop.
Suggestions? Comments?
Jay
Improvisation
The original leak having been through a bad o-ring on the low pressure switch connection, all the refrigerant was blown when I removed the switch because the shraeder valve was bad as well.
Oh Boy. This connection is the ONLY low side access on my system. I don't know why.
My commercial A/C hose connections are different threads than this fitting. This left me with no means to charge the system with the engine running.
This is what worked:
I connected the R-134a bottle to the liquid line. Sprayed the condenser with water and blew a fan on it. Warmed the bottle of refrigerant with a hair dryer. Presto! Three bottles later the system has the required 2 lbs. it came from the factory with.
I am interested in knowing how many other trucks are out there with no connection on the suction line.
Hope this is a help to someone.
Later!
Jay
