I own a HVAC business and have some knowledge of and lack of airflow. My stock airbox with the fender extension was noisy and when I addressed that I found it was trying to draw what I calculated to be approximately 400cfm through a 11. 25sq. inch hole at 70 mph or approximately 2100rpm. Removing the extension helped some but now draws warmer engine compartment air. There appeared to be no way to get sufficient ambient air until I came across the ad for Doug Hofeldt's replacement hood.
I contacted Doug, he built the hood and I went over to have him install it. Paint, fit and workmanship were beyond what I had expected, it really looked good.
On the way home I got to wondering just how good this system was working. I used a digital manometer made by UEI model # EM150 available from most HVAC supply houses for about $100. 00 to check above the filter in the stock box and Dougs new box. Literally hundreds of readings were taken as I found wind, turbulence, grade, altitude, temperature and load changed readings. I ended up averaging all those. The old box at 60mph -. 90 at 70 mph -2. 05, Dougs new system at 60mph +. 10 at 70mph +. 25, With the probe in the hood at 30mph +. 15, at 60mph +. 35, 70mph +. 45, at 75mph +. 60 all in inches water column.
I think Doug had it all together when he engineered this hood. To me this is true ram air. Obviovsly it's possible to pull it down into the negative when accelerating but I was looking for a positive when at cruise speed and I have that so am very satisfied with the performance of the hood.
I don't have mileage figures yet because part of the time I carry a 4600lb camper. I wish I had the ability to measure cab sound level stock and with the new hood, it seems quieter but no way to verify that. I'm running a dynoed 318hp for these tests on level one. I may one day turn the Edge Pro Comp off and try a few more readings.
