amsoilman
Staff Alumni
DonM,
Just to set the record straight here. My truck is certainly NOT STOCK! It has more done to it than my signiture would suggest. I do have larger injectors as well, and a few other things to bring up the power. On the dyno I used, I was putting 305 HP to the wheels, so the truck is definately not stock!
Now let me tell you what my soot levels were at each oil analysis since the Series 3000 5W-30 was installed. At 115,000 (10,000 on oil) it was 1. 0 Percent.
At 120,000 miles(15,000 on oil) it was 1. 0 Percent. The last one taken on 1-3-2001, showed 1. 2 Percent with 31,000 on oil. In talking to the chemist at "Oil Analyzers", Soot particles are somewhere in the 1/4 of 1 Micron in size. In other words, 1/4 as small as 1 Micron... ..... Thats pretty small! He went on to say that as the oil accumulates miles or hours, these small particles become "Aglomerated" (big word) and become larger particles. The Magnesium, Calcium and Barium in the oil as additives, is what helps to keep the particles from "Aglomerating". He said when the soot level reaches 3 Percent, then the oil should be changed. I might also tell you, my Fuel percent was less than 1 Percent as well, and he said if it got to 3 Percent the oil should be changed as well. Now he also said this! Divide any of my numbers by 8 to 10 as this would be the numbers for a "Normal" oil drain, since I have more miles than a "Normal" 3-4,000 drain interval. This would mean at 1. 2 percent, which is the last figure, my soot level would then be around 0. 12 Percent soot. I do indeed know the oil is doing a great job in protecting my engine, like every other engine I have used these products in API Certified or NOT!
And yes, I have posted on other topics many, many times, and I do not get on here to sell this oil. I do however have an ad in the TDR Magazine with other people, and have had for many years, as I have been a member of the TDR since its inception in 1993. Most of my contacts have come from the many TDR rallies I have attended.
And you still haven't responded to the E-mail I sent!
Best regards,
Wayne
Best regards,
Wayne
