Read it again, Don. My soot numbers went back to normal after re-installing the Hx35 turbo. MEANING: the dual bypass CAN, and DOES , keep up with the soot. Because I have enough turbo boost to burn most of the fuel I'm running!
No, not the same oil in my sump. I drained it to be safe. Original soot # for the very first sample, with stock Hx35, and DD3's, and PowerEdge, was <1. 0 PPM.
AFTER the Hx40, it went up to 3. 1. It is now back down to <1. 0 after 6000 miles on this sample.
Twin turbos or Piers new Hx40, or Kurt's B1 will provide enough boost without lag, to burn more fuel and make less soot. If that's still not enough, you are overfueled to the extremes, and need to be changing oil every 3000-5000 miles.
It's not just the soot #'s you look at. You also need to look at the viscosity and TBN. If those change for the worse, along with elevated soot, it's time to drain.
You're so focused on dual bypass systems being used for extended oil drain intervals. EXTREME oil drain intervals. I don't run extended intervals, I go by the oil analysis and my own judgement as to when to drain. The dual bypass systems have the added benefit of extra filtration protection. The synthetic protects my engine on cold starts, and hot towing, and protects the turbo bearings.
The Amsoil could not have caused your leaks, the holes were already there, it just found the holes a lot faster and easier than dino would have . Which is a shame, but any synthetic can do that, whether it's API rated or not. The synthetic flows a thousand times easier than dino does. Put a bottle of Rotella, and a bottle of Amsoil in the freezer overnight. Pour them out in a pan, see which one pours a lot faster. Pour one in your right ear, pour the other in your left ear, see which one comes out your nose faster.
This is logic any mechanic could understand.
NO OTHER SEALS OR GASKETS on my truck are leaking, AFTER 60,000 MILES of synthetics. If they were, too bad, I'd have to change them(if I felt like it, and got tired of checking levels more often), then fresh Amsoil goes right back in it, whether it's engine, axle, transmission, or transfer case. Or run it until it's losing a quart a WEEK. Oh yeah, almost forgot. My steering gear box is leaking. That's the only place on the truck that doesn't have synthetics in it !!!
As for you going to Idaho, why the plane, or on foot? Doesn't the Aryan Nations compound have a driveway, with a security gate? You could just drive in.
