Most tp center tubes are about 1. 625" these days. Here in good old Tulsa Oklahoma, Scott 1000 has a 1. 5" center tube which is exactly what is required for a tight fit on the center post of the Frantz. I have found that if I remove 55-60 wraps it fits very snug in the can. Although sometimes I wonder if I am not getting it in there too tight.
DaveK98, if you look in my reader's rigs pics you can kind of see how I mounted mine. I used a piece of 3" wide 1/8" thick steel and bent it 90 degrees so it had about a 4. 5" leg and a 2. 5" leg. I drilled 2 holes to mount the Frantz bracket on the 4. 5" leg as far up as I could. Then I took the passenger battery loose and slid the 2. 5" leg under the battery and bolted it back down. I have about 6000 miles on it like that and it seems very secure. Plus if for some reason I ever decide I need to remove it, it is very simple to get out.
I need to do a filter change today or tomorrow so let me know if you would like some more pics. I can snap a few while I'm doing that.
Jeff
Jeff
