Kirwin
Picked up our new Holiday Rambler on Tuesday the 28th of January. Noted on the 250 mile trip home that at speeds above about 60 MPH that the trailer can get to swaying pretty good. Enough to move the truck around which is a pretty uncomfortable feeling. First issue was that the dealer didn't set my hitch height high enough as we were towing with a significant low forward condition on the trailer. I have been using the same Reese weight distrbuting hitch (with 750 lb spring bars) since 1991 with now 3 (the new one being the third) different trailers. The new trailer owners manual states that the hitch height is 23 inches but it is closer to 26 with the trailer level. I weighed the trailer in the original height configuration and it shows 1220 lbs tounge weight and an over all weight of 10,160 lbs, giving me a GVW of 17,640. I know I am over my trucks GVWR by 1,640 lbs but if I had the 4. 10 ratio It would be rated at 18,000 and if my truck were a 98 model with the exact same power train it would have been rated at 20K no matter which rear end ratio I had, so I am not too woried. So I talked to the local camper dealer and discussed my new trailers trendency to sway with him. He said that towing with the tounge low was better that towing with the tounge high which makes sense to a point. He recommened a Reese improved dual cam sway control hitch rated at 1,200 lbs tounge weight. I have also replaced my stock reciever with a Draw-Tite Ultra Frame reciever rated at 12,000 lbs. The trailer is on 235/85R-16 E Goodyear Wrangler HT radials. It sets much higher off the road than either of my two previous traliers. SO here are my questions; anyone used this new and improved dual cam sway control hitch? Will leveling the trailer alone make the sway better or worse? Will the 1,200 lb spring bars make the situation better without the sway control portion? As always thank you for your help and input as I try to sort this out. Ken Irwin
