I make the cold fronts for the newer trucks. how does your grille look like? how would say a plastic panel attach to the truck? like a bolt or on the 91-93 I use a J-bolt and cap-nut. It hooks to the center bar.
If you can make a template of the openings with like posterboard and also figure out where the holes will be for mounting, then send it to me, I can make you a set with the plastic I use. (ABS plastic).
I don't know if Lund Makes the cold fronts for your truck or not but if they do, it will be much more $$ I'll bet.
Let me know,
Eric
