..... Now what he said was that despite having enough pressure, the problem is fuel-air mixture entering the injector pump. The air brings down the flow despite good pressure. The FASS takes care of that. He claimed we would get better mileage - 2-3mpg.
Toni, stay away from this scheister!!!! Yes, the Airdog is a great system... I cannot speak for FASS, as I have never owned one, but the two do the same thing, they do separate air from fuel. Will you get 2-3 MPG more? No frigging way. I had the AirDog installed on my '01 3500 in February and I can tell you that my MPG never went up.
. . He also recommended some Juice something or another which would gauge all that can be gauged on our truck and due to a chip we could change driving modes from regular to tow and stuff like that. No price quote. The filters on FASS are suppose to be easy to change, readily available at truckstops and last a long time between changes. The FASS is suppose to have a lifetime warranty.
So they're trying to sell you an Edge product, which is a tuner to modify your fuel and timing... you don't need it; you have plenty of power to do what you need.
The FASS does NOT have a lifetime warranty... the AirDog does. Note that AirDog is owned by Charlie and FASS is owned by his son. The two had a falling out some time ago and the son went off and started FASS.
... Alpine Offroad & Performance indicated that our injector pump most likely failed due to fuel-air mixture and lack of lubrication. They said that diesel no longer has sulfur in it, and you must use additive otherwise your injector pump will die and that many 98's -02's have died from the stupid fuel. We had no idea we were suppose to be adding a lubricant to our fuel. He sold us "FlashLube" Diesel Conditioner - 1 liter for $32. 00. Is this a good price for this stuff? We will have to order FlashLube. Are there any other good lubricants out there that are readily available and don't cost so much? We have always been using Cetane Boost every other fill up, but Alpine said that was not helping.
As the great Colonel Sherman Potter used to say, "Horse hockey!" Your VP44 might have died for a number of reasons, heat frying the VP44's electronics being one of them.
... Our question is - is the FASS system and others like Airdog, etc. really worth all that money? Blue Chip says that the newer versions of the lift pump we have are adequate. We would like to hear back on this because we have no experience to go on: Do you think that we are safe to tow with our current lift pump's performance? Or should we stay and get a better pressure gauge installed - or just get another lift pump from Blue Chip or flush the old lift pump designs for a system like FASS? Is what has been quoted us a good deal or not? And what about this diesel conditioner?
If your LP is 12psi at idle and 10psi at throttle, then you are fine. You don't need all this fancy crap that Alpine Offroad is trying to sell you. Are Airdog and FASS good systems? Yes. Do you need one? No, you don't... . Chip is right. Would I spend the money to relocate the original LP down by the frame? Yep, Gary-K7GLD did it and his setup looks nice... you can pull a search here to find his thread.
Should you run diesel conditioner? Yes, it is a very good idea. Yes, ULSD doesn't have the amount of sulphur that LSD had (15PPM vs 500PPM), but it still does have sulphur. Stanadyne, Howe's Lubricator and Power Service all do a good job. I personally use Howe's and Power Service, because it's what I can find at both Wally World and truck stops, when we are pulling the Airstream. $32 for a litre of any conditioner seems a bit extreme... . You can get Howe's for $13. 00 (and I think it's 64oz. ) and Power Service sells for about $9/qt.
Alpine Offroad sounds like snake oil salesmen who just want to make a fast buck off of people who are gunshy from a recent traumatic experience.
Drive like you normally do and you will be okay.
If you get down around the San Angelo area, feel free to stop by for a fresh cup of coffee.
Good luck.
