KKunz said:
It got down to about -20 or -30 with the wind chill the other night went to start my truck took me about 5 tries and she finally started idled up to 1200rpm just like normal and after a little bit the 3cyl idle kicked in and rpm drop to maybe 250-300 rpm I tried to over ride it by pushing on the throttle but did nothing the truck finally died after about 20 seconds, I re-started it and every thing worked fine just wandering if any one else has seen this happen.
Hey KKunz, I know what you're talking about. My '02 has done this before. I live in the northern tip of Wisconsin. It only did this to be while I was on conventional oil. -28 to -40, it is a total pain to start if not plugged in. Believe me, switch to a good full synthetic if you haven't already. It will make a huge difference. Conventional oil is SO thick at those temps, your engine can barely turn and can't build oil pressure well.
But yep, hard start, had to put my foot in it to get her going. Lots of whining and noise, not pretty. Finally all 6 come on line and it is actually idling without my foot on the pedal. OK, great. So, it starts to ramp up to 1200 rpm, all is good, but stuff is still rough. As soon as the 3 cylinder program kicks in, the 3 that were hitting all the time cut out, and 1 maybe 2 are hitting every time, and at least 1 of the 3 is missing hard. With that and the thick conventional sludge, it instantly died. So, I started it again and ran her up to 1500 with the pedal for a minute or so. Then when it went on 3 again, it held it fine.
Not a fun process, and it is hard on the engine. Plug it in if you can. When I switched to AMSOIL full synthetic, the difference in cold starting was night and day, and that was BEFORE I sold AMSOIL products. That is partially why I firmly believed in AMSOIL products before I turned it into a business.
Whatever you do, do not use starting fluid or the ether bunny.
Bad deal there.
So, bottom line. Normal? Sure, sound like your engine is behaving like it has to. Is it good for it? Nope.
-Chuck
