SnoKing
Did you put the full 12Qts in? If so check your oil if it has been sitting for several hours. Are you about an 1/8" or so over full?
About a quarter inch over!
Snoking
Snoking
I am still using the FleetGuard filters from a one case purchase a while back.
Does your truck like Potter's Vodka ? :-laf
Understand you may have some LF3894 filters from a prior purchase and are using them up. Will you shift to Fleetguard Stratapore 16035 when the time comes?
I'm surprised that no one here has yet commented that you should NOT fill your oil filter when you change your oil.
Several years ago these forums had a story, which has been confirmed true by TDR, about an engine that was destroyed by a tiny piece of aluminum that was poured into the CLEAN side of the filter by a well-meaning owner. When the engine was started, that piece worked its way to a small oil passage and plugged it, preventing oil from reaching a critical part. The engine was destroyed and neither Dodge nor Cummins would repair it under warranty.
Okay, I guess with today's bottles that (mostly) no longer use aluminum seals a careful owner could pre-fill the oil filter, but always remember that you are filling both the dirty and the clean side of that filter. Oil that you add to the sump via the oil filler goes through the filter before it gets to the engine. Some of the oil inside the filter doesn't.
Sorry, I am not willing to take the time to find that old anecdote, but I wanted to remind members about the hazard.
-- Loren
I'm sitting right next to my 3 1 gallon jugs of Rotella and they have the nice caps which break away from the plastic cleanly.
I've owned RAM / Cummins powered pickups since 1997 and have never had a problem with pre-filling the oil filter. I will continue to do so....not only on my RAM pickup, but any other vehicle I own that the location of the oil filter will allow me to do so.I'm surprised that no one here has yet commented that you should NOT fill your oil filter when you change your oil.
Curling up with a nice jug of oil for the evening?![]()
Been pre filling filters for 40 years with no ill effect, just be careful.
On the '13 and up 6.7s, is it possible to get to the filter from under the bottom of the truck and come out with it that way? I do this on my '05 and I have no issues. Works well and I don't have to remove anything.
