Silver600, what kinda RV are you pulling that needs a restricted class A? There is a difference between the commercial license we pay on a pickup and what the DMV and CHP consider a commercial vehicle. I was told the difference was all pickups, unless they have a camper shell, have to be registered with commercial plates, that does not mean it is going to be used for commercial purposes or that they are even a commercial vehicle, its all about the weight fees to pay for the roads. The GN over 10k#'s, or any trailer other than a horse trailer, RV or stock trailer, is considered a commercial vehicle and therefore subject to all commercial vehicle laws and drivers licenses because it is capable of being used for commercial purposes. Not my words, just what I was told by the CHP Commercial Officers I have talked to.
GWbourne, as of now you don't have to go into the scales when pulling a trailer with a pickup in Cal and I was not concerned about being weighed as I would keep my weights legal. The CHP commercial officer around here is just pulling you over to check the GVWR sticker if he believes the trailer over 10k#'s GVWR for the trailer only, don't know if they would buy the weight distribution on the truck with a GN. If you are empty and the GVWR is 10k#'s or less, then fine, if he thinks you are over he may put you on the portable scales and that would be a big time ticket if things didn't jive. One of the ways that I was told they establish cause to pull you over is by looking at the wheels and seeing alot of lugnuts, then they know it at least has the weight capability. Three axles would also be a sign.
I too drive very cautiously towing and have racked up some miles in the last few years without much problem, I just want to find a way to have a gooseneck for the ease of towing, within its weight parameters, without having to fork over the dollars and time for a commercial license as I am just moving small tractors from one of my places to another or up the state to oregon where we also own a duckclub.
Patrick, thanks for the info on the BigTex, I will look into it, it certainly seems like an option, although last time I checked, they were pretty expensive.
