How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
212600--zero engine problems so far. work truck, runs every day in summer and part time winter. 2001 6 speed orig. clutch. oh, I forgot, 1 lift pump.
And now that you have officially stated as such, murphy's law dictates that you will have problems now. . better find some wood to knock. Hurry Man, Hurry...
Sorry , couldn't resist. . it's one of the major murphy's laws that always effects me.
CGoyette said:
Looking at trying to do some statistical analyisis on failure rates first step is mileage. Please be honest and only 24 valves for this post... . More later on types of failures.
Curt
112,000 --1 lift pump, ball joints, clutch and lots of normal maintenance
368K with one VP-44 and three lift pumps. Can't complain, it's been worked hard. Usually gross between 24 and 30K [Have been known to pull 41K] and most of the miles have been hooked to a 36 ft. gooseneck. Don't think that there is a better truck made. I've replaced the front pads twice and the rear brakes are still original. Haven't done much work on it, just normal service. The dealers don't have a clue about how to diagnose or repair them. Don't think that you can operate any other truck as cheap, you just have to learn how to keep them up yourself.
2001 extcab Longbox 4X4
85,500 Truck is in the shop at this time for Lift Pump, Injector Pump, and A/C condenser Leaking. All under warranty. Still wondering wondering why Dodge doesn't have a fix for the problem.
Over 300,000 here. Engine repairs were:
Cummins Reman VP-44 (which was replaced again w/ a new VP-44 that was "updated")
Head gasket that had an exterior coolant leak before "break-in".
Lift pumps @ every 50,000 miles regardless if they were weak or not.
APPS potentiometer.
2002 3500, H. O. 5. 9CTD, 6sp w/U. S. Gear underdrive, 3. 54 Trac-Lok,
No one has touched a wrench to this truck besides me.
150,000 mi. a year & has been parked for the last 3 years other than using it to take an occasional trip.
210,000. Throttle position sensor, rear wheel sensor, sensor in top of diff. , 3 lift pumps.
98. 5, 5 speed
97,000 one lift pump new style and 1 set of ball joints at 40,000. Need to check them again. Two sets of tires 5th sets of brakes original rotors except one rear which I didn't catch in time.
I guess I should update my entry
2001. 5 132k - 4th lift pump,
Hub drivers side (did ball joints and u-joint while apart)
Guess I should do the other side now.
Still original brake pads, rotors.
a/c compressor replaced 35K, 2001 HO. Both mirrors replaced. Presently 92K and shocks need replacing but will probably do the KORE suspension soon. :)
Original batteries and brake pads/rotors.
Bob
Update:
Now I'm at 505,000 Kms ( 310,000 miles) , put on second lift pump today. I was sort of lucky, it failed right in the yard. or I think it did, perhaps it has not worked for some time.
good luck !!!
