How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
187,188. Since we bought it in 2007... .
balljoints(upper and lower),outer tie rods, & trackbar
driveshaft carrier bearing
a/c cycling switch
starter
radiator
fan hub fell apart
alternator
a/c's out again???
2001 Quad cab, 4x4, longbed.
194,450 miles (8-09-09)
Flawed transmissin case-weeped fluid-warranty when new
3 lift pumps. 1-warranty. FASS now---no problems
2 VP44. 1-warranty. 2nd-my wallet. Rebuilt by company who swears the upgraded version will last.
Some module in transmission-warranty
Clockspring recall
High beam switch-warranty
Pressure pump/steering pump seals leaked-warranty
Fan speed resistor
Upgraded to DTT trans at 161,000.
Original tires replaced at 97,000. Second set went 86,000. Running some BFG's now I got for practically nothing. Don't expect over 40k.
This year (09):
Starter solenoid sticks once in a while. Probably replace soon.
Front end needs work. Some up/down in king pins, pitman play, etc. Wanders a bit.
New heater blower motor.
New shocks.
New fuel guage sending unit.
Still like the truck... ... runs great!
155632 as of today 8/10/09
two pilot bearings
one lift pump (changed out at 47k because of low pressure)
head gasket (148k)
bearing in turbo
one set of front pads
vaccumn pump seals
4 lift pumps (last replaced with FASS) all warranty
4 injector pumps (#4 is on the truck now) all warranty
Rear output yolk and seal
Headlight switch (knob pulled off)
Sold 2001 cab and chassis last year with 189K, had steering gear replaced when truck was 1 month old, dumping fluid from adj. bolt on top, 2 lift pumps, and sold when NV5600 grinding 2nd to 3rd, 3rd to 4th, rear main was leaking, and suspected 53 block failure.
I've got 237,000 on my 98. 5
Whats Been Replaced:
3- Lift Pumps, needs another one now, going gerotor pusher at tank.
2- VP44 injection pumps.
1- 47RE Transmission... . probably needs another soon
1- Alternator
1- Starter
1- Center Driveline Bearing
What Needs Changed Badly NOW!:
Track Bar... learning how to do the death wobble
Front Calipers ..... they rattle like a can fulla rocks
Water Pump..... starting to seep ever so slightly
Fan Clutch... cant really hear it kick in anymore when hot
242,000 time for new VP44
Just turned over 242,000 miles and I'm in need of a new VP44. Ordered one from Chip @ Bluechip the other day, waiting on it to come in. This has been a great truck... 01 Dually Laramie, 5 speed, 4" exhaust, Adrenaline with Pulse, and all the bells & whistles.
Have had to replace the lift pump three times (1 under warranty), VP44 injection pump (under warranty), one clutch, 2 sets of brakes, and 4 sets of tires.
01 with 181K
3 lift pumps, current by Glacier 80K ago
injector pump @ 80K
the usual front end probs
pretty much trouble free turn key miles, runnin strong
dg
My current 98. 5 is at 210,000 I don't know how many lift pumps and VP44's,
My prior 99 with a 53 block was at 295,000 when I got rid of it, no cracks yet.
I have a friend with a bone stock 98. 5 auto with 300,000 and (I know you won't believe this) original lift pump, original VP44, and original auto. Just uses it as a car and he put all the miles on it.
104,321 as of today. VP44 at 72,000 replaced w/ blue chip X pump. Track bar upgrade done somwhere around 45,000. Origanal was OK. Just wanted to avoid potential problems. 3 lift pumps. Upgraded to a FASS. Time for ball joints. Frt brakes at 48,000 and again at 101,000, rear brakes at 101,000.
Parked in the junkyard at 137,000
1 lift pump at 60,000 (pre-emptive strike)
full dtt at 75,000
inj pump at 85,000
tires and pads
4200 on my new 09 and its all good
06 mega 73K
1 rear complete axle
Both frt wheel bearings
drive shat u joints
entire dash cluster
3 DAMN blend doors
1 ac/heater blower motor
2 trips to adjust shifter cable
1 more to replace worn valve body
3rd (2 months old) set of tires
Rear axle seal
2 frt pinion seals
1 TIM reset (trailer lights tripped it)
2 nd set of frt brakes (first pair f'ing squealed all the time)
(i think that's about all)
170k
2 lift pumps(before FASS), 1 VP44, 3 sets frt brake pads, 2 clutches(factory, then SBC)
NV4500 rebuilt twice
3 sets tires
2 thermostats
Dana 80 rebuilt
1 frt wheel bearing assm
NV241HD transfer case rebuilt
rebuilt rear drive shaft
half dozen u-joints
Is still a great truck. Had it parked for 13 months once, connected the batteries, got in and cranked up. Still had to un-freeze the brakes...
Jeff
132K on my truck
bought truck 4 yrs ago since then:
new track bar
new front-end
2 sets of tires due to Dodge front-end geometry
1 lift pump... . FASS now-no problems
2 complete high performance transmissions before finally getting a Goerend
1 set of pads for front
brake line for rear brakes rusted through
ECM
new VP-44 still acting up
new dash
starter contacts
new shocks twice
rear end probably needs work-dragging one and spinning other around turns!
before buying truck from BIL he installed a complete new front-end also including new steering box,tie rods,new tb and new tires... . lasted about a year until everything needed replaced again except for steering box. Now that has play again and needs replacement. Truck will pull anything you hook to it,gets great mileage doing it but what a huge money pit and why on earth Dodge decided to put a 1/2 million mile Cummins into a POS truck chassis is beyond me. Including mods of course,which do not count I know,I could have bought a brand new 3/4 ton gasser and paid the mileage penalty 3 times over. Diesels are powerhouses but realistically,you pay the price to own one. I have so much money into that I cannot get rid of it and right when I think I have spent enough to make it reliable again,something else happens! JUNK!!!
I really don't understand how you guys get 5 and 600K out of these trucks... . I have trouble getting to 130K. May be I got a lemon.
Alan
